problem with interpolation
I've got a problem. In my VI there are three different kinds of interpolation. Fpr ma the best interpolation is the Rat.-Interpolation.
But in this Interpolation there are extreme errors. Why?
I need an Interpolation which gives me a
x- and y- value back.
(3,396 Views)
your interpolation are with extreme errors because you have bad interpolation function (you need high polynomial order) and your interpolation data are complicated.
You can try different type of interpolation {no only linear and quadratic}
Look my examples, and example in LV: \LabVIEW 7.1\examples\math\optimiz.llb\Parameter Fitting LM.vi
Best regard
JCC
(3,396 Views)
Thank's for this example.
But how do i get my y-value from a defined x-value?
markus
(3,396 Views)
Hi Markus,
when you use to interpolation function y = a + b * x as in "General Polynomial Fit.vi" with 'polynomal order' = 2 . You must recalculate you require X values over this function.
Or when you want use complicated polynomial {or other } function you can use Formula Node. Look my second part of example. It looking terribly, but it working, and you can use complicated interpolation function.
Have nice day
JCC
(3,396 Views)
