Exit vi (Discard =True) and open another vi
Hi ,
I want to know if there is a methode to Exit the Current vi when OK button ="True" and open/Run  another  (i want the code to be set in the red box ).image1.pngvi
(2,814 Views)
Don't close the front panel, just hide it using a Property Node of the VI (Front Panel Window->State).  If you close all of the front panels, your application stops running.  So hide it instead.
(2,775 Views)
You might be looking for "dynamically starting a VI". A would dynamically start B, and can then safely quit. Note that B needs an open panel or an explicitly opened reference to itself, or it will stop running.
(2,766 Views)
