 Kxg7
			Kxg7
			09-04-2003 02:13 PM
 Evan
			Evan
			09-05-2003 01:38 PM
 Andrey_Dmitriev
			Andrey_Dmitriev
			11-09-2004 06:54 AM
 jkeister
			jkeister
			09-06-2005 11:00 AM
Can somebody give an authoritative answer to this question? I am using get notifier status in a loop with labview 6.1 and I see a big leak. Is this bug fixed in 7.1? I am ready to install it but not if it won't fix the problem.
Jeff
 Joe_H
			Joe_H
			09-06-2005 11:27 AM
 jkeister
			jkeister
			09-07-2005 02:11 PM
OK I would say this is a bug and it is fixed in LV 7.1. I was experiencing big leak with "get notifier status" in LV 6.1 until I updated. Unfortunately this is a tedious process for such a seemingly simple problem. But I would have done it anyway eventually. FWIW, here is the tedious sequence I had to do on my system to get all my components up to 7.1 working together:
LV 7.1, reboot
Remove NI-DAQ 6.9.3, Install NI-DAQmx 7.5, reboot
Iinstall Traditional NI-DAQ 7.4 (need "1easyio.llb"), reboot
Install NI-Motion 7.0 (PXI 7344), reboot
Update flexmotion firmware thru MAX (now v. 3.11) from 5.11 to 7.00
Install NI-serial 1.8, reboot
Install NI-488.2 2.4, reboot
update code to reflect new RS-232 (COM) port assignments, test new code
This is a "large" application (440+ vi's); maybe it's time to join in the "large" thread.
Cheers
