Explain how the DAQ digital inputs work
Hi!
I was wondering how to set what is high and what is low for my digital inputs for my DAQ? I am using DAQ USB-6211.
Thank you for your help!
(4,597 Views)
Accepted by mkapler1
Hi mkapler,
did you read the specs of your USB6211?
The document is quite clear on your question…
(It's a LV-TTL device, able to handle standard TTL on inputs.)
(4,583 Views)
i see the datasheet if USB-6211 DAQ. my program is give the digital input to DAQ.
can i connect external +5Volt to the Digital Input pin(PFI 0/P0.1)?
Based on the this input i perform the operation.
(4,189 Views)
Hi senthil,
digital inputs on standard DAQ devices can handle 5V at inputs.
But: What's the sense in connecting a static 5V to a PFI input?
(4,185 Views)
Hi GerdW,
I connect the proximity sensor signal given to PFI Input. It like as a, when it  sense Input will be high(5V), when not sense input will be low(0V).
(4,182 Views)
Hi Senthil,
you can connect your sensor to the DI pin…
(4,174 Views)
