Explanation of VI
Hello bilko
I will do the necessary
thank you
Message 11 of 17
(1,043 Views)
@Zahkay wrote:
Hello bilko, yeah i did try the Ctrl -H, but it explain only about the specific icon. I wanted to know the sequence of the index array with the decrement. I understand that if the username is same then i can continue or else no.
the explanation behind the scene from that user accound connecting to index array.
this Vi was standard for almost all the online example.
thank you for helping
Sorry, I misunderstood.  I thought you were asking about the index array specifically, not the reason why it was being used.  That requires you to actually understand the nature of the problem you are trying to solve.
Bill
CLD
(Mid-Level minion.)
Message 12 of 17
(1,041 Views)
okie sir
i will do the necessary
Thank you
Message 13 of 17
(1,036 Views)
Oh, and just so you don't feel too bad... I was once guilty of doing the last thing on the list I provided earlier.  I learned from the forum why it's silly to test the state of a boolean.  😉
Bill
CLD
(Mid-Level minion.)
Message 14 of 17
(1,034 Views)
okay thank you for this information
Message 15 of 17
(1,031 Views)
Accepted by topic author Zahkay
I felt compelled to clean up your VI and make is simpler.  I threw in lots of comments as well so you can understand the reasoning.
Message 16 of 17
(1,015 Views)
Thank you very much sir for helping me with the VI as well as the explanation.
Thank you for helping me to be able to proceed with my project
Message 17 of 17
(983 Views)
