Exponent display bug in Context Help
I found a bug but didn't know where to report it so I'm posting it here. (What is the appropriate channel for bug reports?)
When I moused-over "Forward Software Limit Position" on the Property Node of a SoftMotion Axis, the Context Help contained this line:
Valid values are between 0 and 253. The default is 230.
I was confused, as I've been (successfully) using values far beyond that range. Anyway,I opening the Detailed Help and saw:
That's a very big difference! Is this simply a typo, or a result of stripped formatting in the Context Help?
Certified LabVIEW Developer
(2,840 Views)
Accepted by JKSH
Hi JKSH,
I have submitted CAR #390204 to our R&D group for investigation.
Also, here is a link to a page describing the process for bug reports.
(2,809 Views)
