Export Image to Clipboard Crash
Hi Chris,
Can you walk me through the steps that you followed for the workarounds that were mentioned? I'd like to help you find a workaround to use.
Amanda Howard
Americas Services and Support Recruiting Manager
Message 11 of 17
(1,242 Views)
I don't have a work around other than to save it as a BMP and then insert it into whatever document they are using.  I can't find a functional way to export to the clipboard in an exe.
Chris
Message 12 of 17
(1,231 Views)
Hi Chris,
Unfortunately, I'm unable to find a workaround for this as well at this time besides taking a screenshot and attaching the image into the document. Since the Corrective Action Request was filed previously, R&D is aware of this issue and will take it into consideration when developing future versions of LabVIEW. I'm sorry for the inconvenience this has caused you. Are you still able to utilize LabVIEW to make your application successful?
Amanda Howard
Message 13 of 17
(1,215 Views)
This is such a minor part of such a large program that it's really not an issue.  I'll just remove the feature until you get a bug release our on 8.5.  No big deal, I'll just make them save it to a Bitmap first.  Even that is an improvement from what they had.
Chris
Message 14 of 17
(1,204 Views)
FYI, This CAR request number changed recently with the migration to a new CAR database.  The new number is #42403.  Thanks.
Stephen S.
1 Test is worth 1000 expert opinions
Message 15 of 17
(1,001 Views)
This was fixed with the 8.5.1 update.
Message 16 of 17
(994 Views)
I had the same Problem. With the Crash after I create the EXE
It fixied with the new version 8.5.1
Message 17 of 17
(919 Views)
