Export image minor grid
Could anyone help me to solve the problem that I have encountered in the "Export Image"?
I saved a XY graph in BMP format using "Export Image". But, the saved image did not show any minor grids. I think the minor grids would make the plot interpretation very easy.
Thank you for the tips in advance.
Log
(3,463 Views)
Accepted by loges
Try the 'Get Image' Method instead and then wire the Image Data to one of the Graphics Formats VIs such as Write PNG file or Write BMP file.  Set the Image Depth to 24.
(3,452 Views)
Thanks for your reply.
I tried both methods. The "Get Image" plot is not suitable to my report. I like to have a plot as given in "Export Image" (it seems very simple and sweet).
Please find my attachments.
Thanks.
Log
(3,444 Views)
The simplest method is to grab the paintbrush and make the plot background white and the decoration transparent.  If you insist on the 3D smoothbox you can add it back with a decoration that will not appear in the 'Get Image' result.
(3,439 Views)
