Export simplified image failed in subvi
Here is an image of what I was trying to say.
Ben
Message 11 of 18
(2,139 Views)
You mean like this. No go either. Apparently not silly enough. 🙂
Message Edited by lshi on 07-22-2009 01:59 PM
Message 12 of 18
(2,136 Views)
It's actually working? That's wierd.
Message 13 of 18
(2,133 Views)
If you want to open/close the FP without seeing it customize the Windows Appearance to run 100% transparent.  You can set this in the VI itself, or you can run the VI by reference and wire the properties.
Message 14 of 18
(2,127 Views)
Does that mean you have what you need?
Ben
Message 15 of 18
(2,123 Views)
No, that's means it's not working here. I'm just supprised it works for you, cause I did exactly the way you said.
Lei
Message 16 of 18
(2,120 Views)
OK there is the confusion. I did not try it out because that trick (get image ) has always worked for all graphic update issue I have found until now.
The only way i can get it to work is to open the FP before and close just after.
I can't say it is a bug since the FP is closed and it works when it is open.
Sorry the old trick did not work.
Ben
Message 17 of 18
(2,100 Views)
There you go. I think I'll just use the Get/Write Image way or pehaps wire the data to the FP of main Vi and save it from there.
Thank y'all for helpful replies!
Lei
Message 18 of 18
(2,094 Views)
