Export some xy graph values to spreadsheet
I'm newish to labview and i'm trying to extract the values used to plot the XY Graph, but only for x=0,10...90,100 ... 360.
instead of extracting 361 values i need only 37. I tried using another for statement but with no succes.
Any help ?
(3,462 Views)
Hi Lies,
but only for x=0,10...90,100 ... 360. instead of extracting 361 values i need only 37.
Well: "0, 10-90, 100-360" are ~350 values and not 37.
Can you explain how you get that value "only 37"!?
You should only put those values in the arrays you are interested in. Right now you create arrays for a x range of 0…360!
(3,439 Views)
my vi calculates for x = from 0 to 360.
i only need to extract values for x = 0,10,20,30,40,50,60,70,80,90,100,110,120,130,140,150,160,170,180,190,200,210,220,230,240,250,260,270,280,290,300,310,320,330,340,350,360
(3,424 Views)
Your loop count is 361. Why not just drop it to 37 and multiply the loop counter by 10 before using it in your calculations?
(3,406 Views)
Accepted by Lies
Or use the array decimate to get every 10th value from the input array.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,398 Views)
The solution is certainly vaid, but calulating 361 values and throwing away 324 of them is perhaps a tad inefficient?
EDIT - or maybe I misread this - can't see the source code at the moment, and tried to delete my post until I can check again but cant see how Smiley Surprised
(3,364 Views)
