Expression evaluation
Hi
I need an expression evaluator which can resolve an expression at run time.
Can not use formula nodes as they can't be dynamically configured at run time.
What I need is sonmething like the exprerssion editor and evaluator in TestStand.
I.e. the user applies the equation : var1/var2 + (1/var4)*0.1254 - var5.
The variables and their values are known at the time of the evaluation.
Has anyone implemented this in LabVIEW
Kind regards Kahr
Regards Kahr
Certified LabVIEW Architect
CIM A/S
Message 1 of 22
(6,494 Views)
You could use lab python.  I posted this example a few years ago.
Jim
Message 2 of 22
(6,488 Views)
Here's where I ended up after asking a question on LAVA.
Jim
Message 3 of 22
(6,484 Views)
Jim
Message 4 of 22
(6,473 Views)
I'm curious to know if this is useful for your application.  I've seen this use-case suggested in the past and I'm interested to see your solution.
This solution requires you to install Python and the Lab Python tools, but it adds great flexibility in handling your dynamic formula input.
Jim
Message 5 of 22
(6,446 Views)
Or this, which more closely answers your original description.
I'm having fun.  Anybody?  Anybody?  Bueller?  Kahr?  Anybody?
Jim
Message 6 of 22
(6,417 Views)
Haven't found a good solution yet. Need a LabVIEW implemented solution. Not interested in python or other external application.
Regards Kahr
CIM A/S
Message 7 of 22
(6,405 Views)
I just noticed the dll jcarmody. Is python server running in the background ?
Regards Kahr
CIM A/S
Message 8 of 22
(6,403 Views)
kablam!
Parse Formula String.vi and the Eval Parsel Formula String.vi are your friends!
Message 9 of 22
(6,395 Views)
Will the Parse Formula String.vi work for you?  The formula is entered as a string. Most of the fucntions available for the Formula node can be used.  The Formula VIs are in Mathematics >> Scripts & Formulas.
Lynn
Message 10 of 22
(6,390 Views)
