Expression evaluation
Tried it. Option. But have You had a look at the LabVIEW code behind the vi. Oohh.
Regards Kahr
Certified LabVIEW Architect
CIM A/S
Message 11 of 22
(2,578 Views)
And you wanted to write your own instead???
If you have a very limited set of functions (like a 4-function calculator) you might be able to create soemthing simpler, but would it be versatile enough to be useful?
Do you have a description of the possible functions, the number of variables, and the size of the formula?
Lynn
Message 12 of 22
(2,570 Views)
hehe,
Created once a "virtual tag engine" where the user could create virtual tags with math using other existing tags using thoes VI's.. well I didnt have any problems with testing a lot of these tags performance wise (but had a low update freq). However I think in "clean" LV it might be your only option?
Message 13 of 22
(2,568 Views)
I've found implementation of sinus in the parse formula vis. But no ABS, SQRT...
Regards Kahr
CIM A/S
Message 14 of 22
(2,567 Views)
You sure? I believe they can be used as of I can remember
Message 15 of 22
(2,562 Views)
Found the old source code in the library.
Atleast of what I saw:
Abs(), cosh, sinh, tanh, log2, acos, atan, sqrt, ln, ^, acosh, asinh, csc, cot, atanh, log, sin, cos, asin, multiply, minus, divide, add
can be used. prob more
Message 16 of 22
(2,562 Views)
Lynn. The customer asks for trigonometric functions and SQRT, ABS etc. I've allready implemented the 4 function calculator in Labview and could add the requested additional functions but would prefere to use an allready existing and proven one.
Regards Kahr
CIM A/S
Message 17 of 22
(2,561 Views)
Corny. Thanks. I look deeper into it. Thanks
Regards Kahr
CIM A/S
Message 18 of 22
(2,557 Views)
Youll find them all in the LV help: Smiley Happy
Message 19 of 22
(2,552 Views)
@Kahr wrote:
I just noticed the dll jcarmody. Is python server running in the background ?
I just uninstalled Python, put a copy of the dll in the VI's folder and modified the BD to find it.  It ran fine and there's no Python server running.  The documentation for the PYTHON Set Server Path VI says "This function configures the interface to use a particular Python shared library."
Jim
Message 20 of 22
(2,544 Views)
