External files are not deployed to target
I am trying to follow the example in this post where the user specifies a folder in the build specification that has non-LV files.  It contains HTML files that are to be deployed with the project.  It seems to me like a good idea to keep any HTML and JS files with the LV code that they interact with.  When I deploy the project, however, I see that the HTML and JS files are unpacked to /tmp/webservices/userservices/deployed/control-2C7CC494-343D-11DF-811F-00802F112BC5/data on my cRIO.  When I browse to the cRIO, however, I am not served the files since they are not located in the /ni-rt/system/www directory.  Is this a bug in LV or my misunderstanding of the feature?
(2,484 Views)
Accepted by topic author kc64
Found the solution.  The target does not have to be in the /ni-rt/system/www directory.  Carefully following the instructions at http://zone.ni.com/devzone/cda/tut/p/id/7747#toc15 provided the solution.
(2,461 Views)
