tdms property read slow
I have seen a major difference in time for reading properties from TDMS files between Labview 86 and 90
 I see 141 MS in 86 and 1200 MS in 9 . to read the same file
Has any one else seen the slowdown?
jim
(2,965 Views)
Jim,
In 2009, some improvements to the TDMS file format were introduced to increase writing speed:  TDMS File Improvements in LabVIEW 2009
So I'm not sure why you're seeing such a performance hit. I take it you're running the same code on both? Can you post a simple example of what you're doing and how you're benchmarking it?
Misha
(2,960 Views)
It is nice LV9 has improvements for file writing but I am talking about reading properties in the file  . I can't really post the code -- short of creating a simple version I will try later
(2,949 Views)
I found the problem with my code -- no problem with library Jim
(2,912 Views)
Thanks for posting back, Jim
Misha
(2,891 Views)
