External image display window and mouse scrolling
I am using Labview 2011 with the Vision Dev. Module.
I create an external display window of images (IMAQ Browser and WindDraw) with a visible vertical scrollbar.
The scrollbar works when I select it with the mouse to navigate up and down in the images but I can't use the mouse scrolling instead. This scrolling could be more "smoothed" when there is a lot of images.
Doas anyone have an idea how to solve this ?
Is it possible or not ?
Is there an other solution ? I precise that I use the Browser because I want to keep the possibility of the image indexation (done with IMAQ WindLastEvent and Browser Focus).
Thank you !
Nico.
(3,191 Views)
Hi Nicolas,
Unfortunately, mouse scrolling isn't possible in Winddraw pop-up image.
I wish you good luck with your application
Adrien M.
Certified LabVIEW Developer
National Instruments France
Travaux Pratiques d'initiation à LabVIEW et à la mesure
Du 2 au 23 octobre, partout en France
(3,147 Views)
