FPGA compiling- Timing violation Error
Hello all,
I am having a timing violation error while compiling my code to FPGA. I read the NI suggestions for solving this problem but it seems that none of the works for me. For example I can't use single-Cycle Timed Loop (SCTL) instead of the while loops because SCLT does not support the things inside my loops. I do not know what to do. Could you please take a look at the code and give me suggestions?
 (using NI SBRIO-9632 400 MHZ)
Best,
Samira
(3,523 Views)
Using multiples of the same I/O node leads to timing issues on the FPGA, because of the arbitration resources required.
I would make a seperate loop to read/write global variables to 1 I/O node and replace the I/O nodes your provided code with reads/writes to the global variables.
The attached VI can use some clean up, but this minor change should get you running.
(3,458 Views)
