External library Same name of lib for windows and linux
I have a VI library, under Windows. This library contains a bunch of SubVI who call our libAPI.dll We are currently adding support for Linux. And, thus, have the equivalent for our libAPI.dll which is libAPI.so for Linux. Is it possible to use a generic name in the field for Library name or path API (without .dll or .so). So that when we will create of Linux version of this library we wont have to edit all of the Library name or path for each VI. We already tried to use the subVIs under Linux. Labview asked to locate libAPI.dll. If we choose libAPI.dll, then it works fine, but we do not want to have a question asked to the user about locating API.dll under Linux.
Nitrof
(2,555 Views)
Use "libAPI.*" in the call library function node configuration page.
(2,555 Views)
