Extract Single Tone Information, Phase algorithm/formula
I am using the Extract Single Tone subVI in order to make phase calculations for a research project. The phase measurements seem to be quite accurate. For my report I need to be able to state how the phase measurements are calculated. Is there a relatively compact way to state the formula that LabVIEW uses to make these measurements?
(2,945 Views)
Accepted by Zipmeister
Reading the detailed help file will give you a formula.  If you want more details, open the block diagram and observe that it performs an FFT on the input data and then uses a peak finding algorithm to interpolate the exact frequency from the three dominant bins.
Lynn
(2,941 Views)
