Extract Single Tone Information from Hann Spectrum
I need to examine the details of "Extract Single Tone Information from Hann Spectrum.vi" but i couldn't because it is password protected. How can i remove this password?Is it NIs strategy to set the password to some vi's?.Or is there any other function behaving like "Extract Single Tone Information from Hann Spectrum.vi" so that i can see inside?
Regards.
(7,686 Views)
The VI is password protected due to a combination of patents pending and intellectual properties. The code is written in LabVIEW but as you probably noticed most the low-level analysis functions (like FFT) are included in a .dll file that you can't read either. This is just a special case where we decided to keep the original source code in LabVIEW but consider the feature a low-level code.
Let me know what details you are interested in and I'll provide you with the necessary information.
The Designer
(7,686 Views)
I need to implement this function in MATLAB,but I don't know how it works. I put necessary data to its inputs and saw the results but I failed to obtain same results in MATLAB. So, If you send me the details of the function I would be grateful. Best Regards.
Cengiz Eken
(7,686 Views)
I have attached a Power-Point presentation from NI-Week 1999 that describes the algorithm concept and performances. Note that the function shipping with LabVIEW is more complex (and more accurate) than the one described, but I hope this will give you a good idea on how things are implemented.
(7,686 Views)
Thank you for your halp and .ppt file. I have just completed implementing the code in MATLAB, thanks to you,great.
Regards.
(7,686 Views)
I need you help,can you share your matlab code? Thank you.
(5,484 Views)
Hi lishoujie,
do you really think you will get MATLAB code in a LabVIEW board, asking in a 14 year old thread? (TMM was active the last time in this forum 7 years ago!)
When you need help you should create a new thread and describe the problem you want to solve (with LabVIEW)!
(5,477 Views)
