can't find hdl interface node
I have labview 8.6.1 and installed the core CD and FPGA module. I can't find HDL interface node anywhere. What am I doing wrong?
Message 1 of 9
(7,002 Views)
On the FPGA block diagram, did you check in the Programming -> Advanced palette?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 9
(6,987 Views)
Yeah. there is no Advanced Palette for me..
When I try to locate this function using Help, it gives me an error that says
Object not found: the possible reasons include
the object might exist in a different palette view
the object might not be supported on a target in the project explorer window
the object might belong to an installed package that now has an expired license..
and I got the license from my college, so it should be good throughout the year....
Message 3 of 9
(6,965 Views)
What are you targeting?
Adnan Zafar
Message 4 of 9
(6,958 Views)
Hi dahhhh,
I agree with Adnan, I would make sure you are targeting your FPGA, otherwise the Advanced palette will not be available.  To do this:
1.  Right-click the project name in the Project Explorer and select New»Targets and Devices.
2.  Expand Real-Time CompactRIO and then select your cRIO on the network.
3.  Once the target system has been added to your project, right-click FPGA target and select New»VI.
You should be able to see the Advanced palette when you right-click on the block diagram.
Message 5 of 9
(6,947 Views)
Yeah I think that's the problem..
Thanks!
Message 6 of 9
(6,945 Views)
I have the same problem, and I followed all the steps. Still the advanced tab is not visible.
I am targetting cRIO-9063 with LabVIEW 2018.
Regards
tahi
Message 7 of 9
(4,911 Views)
Please start a new thread.
The "I have the same problem" is rather obscure when the original discussion has been dormant for a decade.
Message 8 of 9
(4,903 Views)
The problem was solved.
I just checked, FPGA module and Xilinx Vivado was not installed.
Message 9 of 9
(4,895 Views)
