Extract Single Tone Information.vi configuration help
Hello.
I am trying to measure speed from a sensor that outputs the speed directly to frequency (i.e. 500 Hz = 500 RPM).
I am using the Scaled Window.vi with Hanning and the Extract Single Tone Information.vi to get the frequency.
I successfully measured to about 500 Hz with the default settings.
My range is from 0 to 2500 Hz.
The only settings I can find that seem to let me configure sampling is the approximate frequency and search (+/- % of Fsampl.)
These defualt to -1 and 5 respectively.
I assume this means no default frequency, or 0 and the sampling rate is 10000 (500 / 0.05).
I changed the approximate frequency to 1250 (my center frequency) and the percent to 12.5 (10000 / 1250 ).
This resulted in labView only reading one seemingly random value or not updating this measurement.
After putting -1 in the approximate frequency again, I was able to read values higher than 500, but they folded around 500 (i.e. aliasing).
How do I change the settings or use another vi to get the range that I need?
Thank you,
Electro-Frog
(3,239 Views)
Increasing the sampe rate / per second will increase the range that the FFT will be calculated over.  Total samples doesn't make a difference iti s dependent on the rate of samples.  i was running at 10,000 per second and the FFT measure form 0 to 5,000 so I think it is sample rate / 2.  Just experienced this a few weeks ago so give it a try and let me know your results.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,234 Views)
Thank you very much mfitzsimo…,
That did the trick. It has been so long since I changed the sampling rate, that I forgot it was there.
Apparently the Extract Single Tone Information does all the calculations for you, based off the sampling rate of course.
I bumped it up to 10000 samples/sec from 1000 (where the 500 folding came from) and I could read everything my function generator could put out.
Electro-Frog
(3,231 Views)
A nifty piece of information that took me a bit to figure out.  Have Fun!
Matthew Fitzsimons
(3,226 Views)
