Extract an array from an array of clusters
Hello everybody,
I have got an array of parameters, each one being represented by a
cluster of a name and a value.
I need to extract either just the names, or just the values, as an
array. Is there a standard VI performing that (so far I could not find
it), or must I do a loop by myself?
Thanks in davance
Pierre Chatelier
(3,355 Views)
You nust do a loop. But it only loop where you use unbundle by name for example. Use enable indexing and you will get your array.
(3,355 Views)
Hey Pierre,
Best bet is a For Loop using auto-indexing with nothing wired to the
iteration terminal... the input is the "array of clusters" with indexing
enabled... inside the loop, I've found that "Unbundle by Name" lets me see
what my output array is made up of... then, enable indexing on the output
and you have your array of elements.
Good luck,
Bill
Pierre Chatelier wrote in message
news:803b2d87.0206030059.102f98af@posting.google.com...
> Hello everybody,
> Tha
nks in davance
> Pierre Chatelier
(3,355 Views)
