description and tip
I am giving a tip to one control on the front panel. But, it doesn't show me the tip each time I run a VI. If I right click & pop up menu, then tip displays otherwise it is not showing tip. I have also tried to give tip programatically. But, same problem exists. If there is no loop delay even of 10 ms, it works fine. What may be the problem?
(3,141 Views)
I use a virutal window program on my computer, and I could not get the tip strips to work until I turned the program off. The tip strips then worked like a champ--they showed up when you program was running and when editing. I changed the wait in your program to zero ms and 5000 ms and with both waits, the tip strips worked. I am using LabVIEW 6.1 on Windows 2000.
Jeremy Braden
(3,141 Views)
