Extract data
I am developing a VI to extract info from a output format. I have made an example VI in order to extract the important information about heave, roll, pitch, heading, error code etc.
1. This example VI which I developed is for a single format but if I want to run this
2. The extracted data for 1min should be averaged with in that excel file
3. I wish to call only the average data in the VI and feed that data to the servo loop or PID loop
Please let me know how can I improve the attached VI.
(3,228 Views)
For averaging the data you can use 'Mean' function under Mathematics.
(3,227 Views)
I wish to continously use save and feed the average data, call the averaged data and feed to the servo loop/PID loop
(3,225 Views)
Am not sure whether i have understood your question properly but yes you can conntinously and to the same 1D array number connnect as input to the 'Mean' Function hence the output will be averaged data which can be feed to your servo/PID loop.
(3,223 Views)
