activex windows explorer control
Hi All
I would like to have a windows explorer control on my VI Front Panel and not a seperate pop-up window.
How can I implement this?
I have found some examples with a windows internet explorer embedded in a Front Panel as an activeX control but I don't know how I can call an windows explorer/file browser.
For a better understanding I enclosend a printscreen of what I mean.
Merry Christmas 😉
Stay Hungry, Stay Foolish
(6,583 Views)
What you have in the picture is an OpenFileDialog window.  It's designed to be an seperate dialog window.  Not sure if you can use it in an ActiveX control.
George Zou
(6,572 Views)
As stated, that's a dialog window, so you can't embed it as an ActiveX control. What are you trying to do? Do you want to have an Explorer-like control? If so, there's a few of these on the market. If you Google for them you'll find them. For example: http://www.ssware.com/fileview/fileview.htm
(6,566 Views)
I would like to show the user an embedded file dialog to open a file but I'll need it just once so I cannot spend money on that.
(6,553 Views)
Maybee you should look in the .NET Direction as well.
Basically what you need can be done with a ListView Control that is part of Windows.System.Forms:
http://msdn.microsoft.com/en-us/library/s2edxtd5%28vs.71%29.aspx
The Drawback will be that you have to write the Code that populates the Control yourself.
In addition i found this Control:
http://www.codeproject.com/KB/cpp/VbNetExpTree.aspx
Since you dont whant to pay anything you should look out for Open Source Software
Best Regards
Moritz M.
(6,546 Views)
