Extract header and Data from Spreadsheet string/file
Here is a couple of things which may help you out, for the future, if not for now.
  1. For passing around data sets, check out the techniques in Managing Large Data Sets in LabVIEW.
  2. For large application design, check out the NI-Week 2004 tutorial I have attached.  It will even increase your vocabulary in amusing ways Smiley Tongue
Sounds like you are on the right track, though.  Good luck.
Message 11 of 13
(1,047 Views)
thanks for the info,
As of right now the largest files or arrays that I am making are 4600 x 500. So far I have not had any issues with memory or running very slow.
As for the organization I am planning on going back and fixing some of the issues with confusing programming code.
Thanks again
Christian
Message 12 of 13
(1,040 Views)
Damm I wish the company would upgrade labview Smiley Sad
Message 13 of 13
(1,038 Views)
