Extract numbers from string
I have image files and I want to extract the nuumbers in the image file name. All my image files look like this:
I want to just extract the number after the first x and the second x. I have tried using Match Pattern and then converting them with Fract/Exp String to Number but the output is not always constant of the position I need. How would I go about this?
I have not lost my mind, it's backed up on a disk somewhere
(9,470 Views)
Hey,
either take the scan from string function
or split the string at the x to extract the value
CMW
(9,469 Views)
How will I scan from the first x take the number and scan the second and take that number also?
(9,458 Views)
Accepted by PauldePaor
How about using "Spreadsheet string to Array" like this?
(9,449 Views)
or this way,
btw: I wouldn't use special characters and dots in file names.
CMW
(9,441 Views)
Using regular expression
(9,402 Views)
