Extracting Text From Latest Generated Text File
My code is creating log files in specific folder Report every time I run the code and text files are named in the format: %d %m %y____%H %M %S.txt. For Example: 09 07 24____14 50 03.txt.
I want to extract some text from the latest generated text file and display it on front panel. I am using List Folder.vi to extract the names of every text file in the folder. How can I proceed further. Kindly guide me. I am Using LabView 2017.
(1,629 Views)
Hi qureshi,
I recommend to change the filename formatting to %Y%m%d_%H%M%S (without spaces, year before month before day): it helps when sorting the files…
Once you got the array of filenames you can convert their filename back to a timestamp and search for the latest timestamp: you KNOW the filename formatting!
(If you would follow my suggestion for filename formatting you could even sort the array of filenames and pick the first or last element after sorting…)
(1,610 Views)
Kindly explain it by implementing it in LabView.
(1,606 Views)
Accepted by topic author qureshi000
Hi qureshi,
  1. Change the formatting of your filenames as suggested: do you really need help in editing a string constant?
  2. There is a function to sort a 1D array and a function to index array elements: do you need help in wiring those functions?
(1,577 Views)
