Extracting a smaller array from a larger array
Greetings,
I can't seem to figure out how to do this, but it seem simple enough on paper.
I have an array with N rows and 48 Columns.
Where N>301
I want to extract the last 301 rows from this Nx48 array. (So rows N-300 to N)
How can I do that?
(3,698 Views)
Accepted by topic author nlis12
You can use Delete From Array and delete the first 300 rows.  The remaining rows will be returned to you.
aputman
(3,686 Views)
How can I do that?
Use Delete From Array and only wire the length for the row.  Leave the Index unwired and it will default to deleting from the end of the array.  So the Deleted Subset is actually what you want to keep.
(3,662 Views)
So simple thanks!
(3,655 Views)
