Extracting one column from Database
Excellent!
P.S. Are you coming to NIWeek?
___________________
Try to take over the world!
Message 11 of 46
(8,067 Views)
Unfortunately not.  Can't put the finances together this year Smiley Sad
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 46
(8,053 Views)
Mike,
please send the VIs for LV7.1.
Thanks in advance.
Karthik
Message 13 of 46
(8,020 Views)
@kkronline wrote:
Mike,
Look at post #10 and then give Mike a lot of stars.
___________________
Message 14 of 46
(8,016 Views)
Hey Mike (or any interested users out there!)
I'm banging away on my main application and have made use of your DB tools, mostly just the basic ones. They work great. But I was wondering about your advice on writing a large amount of data into the DB. It goes something like this:
1) The operator hits the test buttons
2) 80 unique pieces of data are generated, mostly numeric, a few boolean, some string. My program shoves them all into a cluster (with clsuters in it) and passes it to a Write DB VI.
3) I want all of these items to be entered in a single DB row. Date/Time Stamp, Part Number, Serial Number and then all of the other stuff
Seems like the only way I know how to accomplish this is to write an enormous INSERT statement explicitly using the name of each field and then use the Execute SQL VI. Is that about it for options?
Paul Johnson
Renco Encoders, Inc
Goleta, CA
Message 15 of 46
(7,857 Views)
You can try doing something like the attached VI (I believe this is based on code originally written by Jean-Pierre Drolet), but you should note that this is not tested code, it was just a quick example.
You will need the OpenG data tools package to do the variant cluster parsing.
___________________
Message 16 of 46
(7,863 Views)
I'm not able to open the file, I must not have the correct tool set.
Paul Johnson
Renco Encoders, Inc
Goleta, CA
Message 17 of 46
(7,846 Views)
Follow the instructions at the link and then download the data tools package (you will also need the string package).
If you want another approach, you can try modifying Ben's example here.
___________________
Message 18 of 46
(7,840 Views)
Mike,
Your database drivers are totally awesome... Thanks so much for your contribution..
min
Message 19 of 46
(7,484 Views)
I may be to late, but can you backsave these to v 6i?  They'd help me out quite alot.
Mark
Message 20 of 46
(7,324 Views)
