Extracting string data from event structure
Hi All
Mech Engineer trying to play the automation engineer role. I am setting up a safety test room with Ground Bond, DC Withstand and Wattage testing. I am attempting to alter the sample VIs provided with the GPT-9000 and write the final test results to a spreadsheet. I have been unsuccessful in getting the string data out of the event structure while only exporting the final results instead of the live running data. If I pull a string from the case structure housing out of the event structure the string is empty. What I am really looking for is to output the final test shown in the front control and have it saved off to the spreadsheet.  Any help is appreciated for this novice!
(943 Views)
Your event structure output tunnel is set to "use default if unwired" and will only output any data if the event structure ends in a case where it is wired. There are many solutions to this, for example you can carry the data in a shift register and wire it across all event cases where it should not change.
I recommend to do a few basic tutorials about the principles of dataflow.
We don't analyze pictures. If you want specific help, please attach your VI.
(934 Views)
Thank you for the guidance, I have updated to include the VI instead of pics. I will research shift registers and data flow.
(914 Views)
Most here don't have LabVIEW 2025 and thus cannot look at your VI. I recommend do do a "save for previous" (e.g. 2019) before attaching.
(908 Views)
