Using LabVIEW with Mettler Toledo Balance. HELP!
I am designing a VI that will take a weight measurement and graph it. I have figured it out so that I have a stop button and a graph. What I need now is a Zero and Tare button. It would be nice to get the proper format on how to use this Mettler Toledo Device Palette so any info would be awesome.
Later down the road, I would like to add a time stamp for each second and a test ID number for each experiment.
I have tried everything! Please help. I am new to LabView and would like to hear all the guidance that I can get.
Thank You
Mike
Message 1 of 9
(9,496 Views)
I think you might need to be more specific about your questions.  And perhaps upload your existing code so we can understand.
And you should probably learn some LabVIEW basics.  It seems like your question is more like "how do I add a button and make it do something" ... which is not really specific to your Mettler Toledo balance.
NI.com has lots of resources for you.  Start here:
https://learn.ni.com/learn/article/labview-tutorial
http://www.ni.com/academic/students/learnlabview/
http://www.ni.com/white-paper/11804/en
http://www.ni.com/white-paper/7466/en
And I am guessing that the LabVIEW device driver for your balance came with some example code?
http://www.medicollector.com
Message 2 of 9
(9,487 Views)
Attached is my code. I want to add a button for zero and tare. I know it's most likely simple, but a hint on how to do so would be much appreciated.
Thank you,
Mike
Message 3 of 9
(9,480 Views)
Accepted by topic author Mike227
You should learn how to use case structions.  See below.
Message 4 of 9
(9,469 Views)
okay thank you! Your guidance has helped me achieve a Zero button. I will continue reading up on case structions.
Now, for the tare weight, would I simulate the same process?
Also, I would eventually like to create a time stamp for each second. I need to extract all data to a .CSV file.
Any hints would be greatly appreciated.
Thank you,
Michael C.
Message 5 of 9
(9,465 Views)
I have the same issues. Could you please share a copy of your finalized code with me. Thanks.
Shuna
Message 6 of 9
(4,390 Views)
i use this code to retrieve the mass displayed on the screen.
I have a Mettler Toledo  : ML6001T Modèle
Message 8 of 9
(2,518 Views)
Could you please share the command you send to the tare?
Message 9 of 9
(2,091 Views)
