Extracting subset array from mixed signal graph
When zooming on a mixed signal graph, is there a property node to get the min and max indexes of the signal array, instead of the xscale minimum and xcale maximum value?
(3,216 Views)
Nope, but if you have those minimum and maximum values and you have the graph data, you can pretty easily get the corresponding graph values for the edge from the data.
Cheers
(3,213 Views)
Accepted by nstjean
Indeed!
Thank you
(3,192 Views)
