F->T rising edge detection
I'm trying to figure out any way or somethink, which detects the rising edge and the output value will be true (when the state changes from 0 to 1).
So if the input is 0, output is false. When imput is 1, output is false. Just that moment between 0 and 1 should be True at output.
Do you have any advices plese? 🙂
thanks, pelda
(9,616 Views)
A shift register and the Implies function.
Lynn
(9,615 Views)
Accepted by topic author peldao
Feedback node and greater than function.
Or boolean Crossing Pt by Pt.
(9,599 Views)
Thank you very much.
(9,531 Views)
