F3 does not trigger "Key Down?" event, but other function keys do.
Hi all!  So, in writing my app I noticed that the F3 key does not trigger the "Key Down?" filter event I have in my Event Structure, but the other function keys (F1, F2, F4-F12) all do.  I can tell because I have an indicator set to show what VKey was pressed and it never shows F3.  It brings up a search window when I'm on the Windows desktop, so the key does work.
Anyone have any idea why LabVIEW finds F3 so special?  I do plan on using some of the function keys in my app, but not having F3 is no big deal; I'm just curious why it doesn't work.
This is on LabVIEW 2009 (with f3 patch) 32-bit on Windows Vista 64-bit.
Thanks!
Message 1 of 12
(4,587 Views)
I have no issues with the following code on Windows 7, 32 bit. LabVIEW 2009.1
Ton
My LabVIEW Ideas
Message 2 of 12
(4,579 Views)
Hi J,
also no issues (LV7.1 and LV9.0f3)...
Message 3 of 12
(4,574 Views)
D'oh!  I forgot to mention that my event is linked to a string control in my program.  The VI snippet posted by TCPlomp works fine and F3 appears to trigger the event.  However, once I modify that snippet to add a string control and link the event to the control then F3 no longer works.
I don't know why the wires are broken in the snippet any why the Event isn't assigned.  So here's the VI also.
Message Edited by The J on 04-19-2010 12:23 PM
Message 4 of 12
(4,554 Views)
The Event case  have no event to trigger off and need redeifining. If F3 is the trigger for a Value change in a string control, why are you not reading the "String" - Value change event?
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 5 of 12
(4,549 Views)
The event case is properly linked up in the attached VI; however, I don't know why the snippet itself (which is from the attached VI) is broken.  The attached VI is a modification of the snippet that was posted earlier by TCPlomp.  His snippet worked as is, but it showed the same problem when I modified it.
I should probably try to explain what I want to do.  The app I'm working on is a serial console.  I use the "Key Down?" filter event on the main text area (console window) of my app because I need to be able to trigger different actions based on the key pressed.  For example, pressing a normal key allows me to just send that character over the serial port, pressing Enter sends the proper line ending sequence (CR, LF, or CRLF), and I want to be able to use the function keys to set up string macros.  Basically, you can map a serial command to a function key and pressing it will send that command plus the proper line ending over the serial port.
The reason why I use a filter event is because I can discard the event if local echo is turned off.
I can certainly deal with not having F3, but I'm just curious what makes that key so special.
Message Edited by The J on 04-19-2010 12:47 PM
Message 6 of 12
(4,541 Views)
Maybe F3 is setup as a special key for your OS on your PC setup by your manufacturer???
- I can't download the snippets 'cos I'm working in 8.6 at them moment, so I'm working on what I could see and think of.
James
Message 7 of 12
(4,537 Views)
That's actually what I was thinking, too.  That F3 must be some special key.  In Windows Vista, F3 opens up a search window, so it is a special key in a sense.  Then I found that TCPlomp's snippet does work with F3, which is why I'm curious.
Thanks for the responses!
Message 8 of 12
(4,534 Views)
Since your posting of the code snippet didn't work, can you post the actual code?
Message 9 of 12
(4,525 Views)
The VI should be in the bottom of the message with the snippet, but here it is again in case it didn't attach correctly.
Message 10 of 12
(4,517 Views)
