FB Node: Initialize on First Call
Hi all,
Not sure why, but my Initialize on First Call option on some of my feedback nodes is disabled.  Can you tell me why?  Thanks!
Yik
Kudos and Accepted as Solution are welcome!
(3,330 Views)
Please post a VI showing this.  What exactly do you mean by disabled, as in you can't wire to it?
(3,326 Views)
Accepted by jyang72211
The feedback node can only be globally initiallized unless you wire a value to the initialize terminal.   When you wire the initial value the other options are enabled.
The help for this is a bit lacking but if you select the Feedback nodes properties page it is explained there
Message Edited by Jeff Bohrer on 03-16-2010 03:36 PM
(3,322 Views)
