FFT Hanning Window as Variable on front panel
I am writing a VI to connect to a scope (Agilent 5400) and among other things to be able to calculate the FFT from the original waveform.  I am using the FFT (Value-phase) and in the attached code you can see that it is now set to Hanning.  I would like to have this option variable on the front panel as I will eventually make a .exe from the file and would like the option to change the Hann to rectangular or Hamming directly at the front panel.  I see that in the help file there are some numbers associated with each option, can I make a varible or use a string to have the user input a number to link to the FFT and change the way the FFT is calculated.
 Thanks in advance
(2,901 Views)
Right click on the constant that says Hanning, and select Change to Control.
Now it will be a control you can modify on the front panel.
(2,883 Views)
Why did you post this question twice?
I'm happy to see that you got the identical answer in the other post.
(2,877 Views)
