How to get cursor coordinates in a 3D plot?
I have a 3D plot with discrete points. The cursor is shown and snapped to nearest point so that I can move cursor around to select one point. I was wondering how I can get the cursor coordinates in this 3D plot so that I can highlight the point (change the size or shape) which cursor is located at. I was not able to find the coordinates using property nodes. Any suggestions will be appreciated. Thanks.
Xueliang
(3,586 Views)
Accepted by topic author xhuo
Is this homework?
THis thread  offers tips to hwo to use the 3d graphs.
http://forums.ni.com...=161218#M161218
This one apperntly has an example for grabbing the cursor values.
http://forums.ni.com...=108612#M108612
Ben
(3,581 Views)
Thanks, Ben. It has solved my problem.
It is my research project. I need to interact with a 3D plot to select and remove outcast points.
Xueliang
(3,566 Views)
Can you please mark Ben's post as solution to your problem so that others in the future who are facing same kinda problem and looking for a solution will catch your thread and get their problem solved immediately.
(3,555 Views)
