FFT Power Spectrum weighting mode exponential
In the FFT Power Spectrum VI using weighting mode exponential from the link:
https://zone.ni.com/reference/en-XX/help/371361H-01/lvanlsconcepts/average_improve_measure_freq/#Wei...
Weighting is applied according to the following equation.
where Xi is the result of the analysis performed on the ith block, Yi is the result of the averaging process from X1 to Xi, N = for linear weighting, and N is a constant for exponential weighting (N = 1 for i = 1).
For exponential weighting, N is a constant. What is its value?
(4,323 Views)
Hi KBerger,
That's an excellent question, I agree that the language used there is a bit vague, I'll look into it and see if I can find anything more conclusive. Thanks!
(4,289 Views)
You define the N value. The FFT functions have a count input for the averaging. This is your N.
The higher the N, the lower the weight of each new sample compared to the average (= the less change each new sample will cause on the average).
For instance, when your N is 10 you have Yi = 0.9 Yi-1 + 0.1 Xi, with 100 you have Yi = 0.99 Yi-1 + 0.01 Xi.
(4,271 Views)
dan_u
Thats what it states/uses for linear weighting "N = for linear weighting". Looking for when using exponential.
(4,263 Views)
Accepted by KBerger
Yes, but N=i doesn't mean it is constant. For linear weighting N = i means N=1 when i=1, N=2 when i=2, ... And averaging stops when i reaches your defined count.
For exponential weighting N is constant (the count you define) which leads to an exponential weighting. The averaging never stops in this case.
(4,261 Views)
OK Thank you.
From the NI FFT Power Spectrum VIs help, it states for N and weighting:
number of averages specifies the number of averages used for RMS and vector averaging. If weighting mode is exponential, the averaging process is continuous.
This could be stated more clearly (to me indicates for exponential N is not used).
(4,254 Views)
I agree this can be misunderstood.
You can post an idea in the LabVIEW Idea Exchange.
@KBerger wrote:
OK Thank you.
There's a Kudos button and you can mark posts as solution Smiley Very Happy
(4,247 Views)
