(FFT) #harmonics of valve acceleration in dependance on steer angle
Hello everybody,
In my program I have data of valve acceleration in dependance on steer angle of half-time shaft (sorry maybe using bad english terminology). I Simply have angle (not time) and acceleration. I've to see all harmonics (amplitudes) of this signal. I know the correct result from other program (FAMULUS).
At first I tried "harmonic destortion analyzer" to obtain harmonics, but it was far from the correct result. Then I started the process of "trial and error" and I succeeded . Problem is that I don't understand, how is that possible. I used express vi "Spectral measurements" with NO WINDOW and MAGNITUDE(peak). I thought this can produce only continuous spectrum, not # harmonics.... Are this really harmonics?
I used other VI as well, it computes same shape but with different amplitudes...
As you maybe realised I don't understand FFT and the things around very well.
Thanks all
Using LW 7.1, WXP SP2
LV 2011, Win7
(2,642 Views)
Are you trying to relate instantaneous valve acceleration to camshaft angular position?
Are you trying to do this over a range of camshaft speeds as well?
I got too many hits were returned by Goolge to make sense of the reference FAMULUS.
(2,630 Views)
