FFT real and imaginary part in Labview
Hello all,
I have a very quick question, After performing a FFT in LabView, I want to isolate the real part of the FFT from it Imaginary part for further treatment. Which VI should I use? Could you please direct me step to step to it?
Is it possible?
Many Thanks for your help.
Israel
Message 1 of 8
(5,237 Views)
You could try the VI
FFT Spectrum (Real-Im) VI Located in the Waveform>>AnalogWaveform>>Waveform Measurement Subpallete.
Note: This Requires: Full Development System
Message 2 of 8
(5,235 Views)
Accepted by topic author israel.haifa
In the Numeric >> Complex palette you will find the Complex to Real Re/Im primitive.  This will work with arrays such as those which the FFT VI generates.
Lynn
Message 3 of 8
(5,209 Views)
Hello Lynn,
Your Feed back was great thank you.
Israel
Message 4 of 8
(5,170 Views)
The thank Lynn by clicking the kudoes button under his name and logo.  And also marking his post as the solution to your question rather than your own thank you message.
First you will have to go to the options menu to the upper right of your last message to unmark it as the solution.
Message 5 of 8
(5,157 Views)
Hello ,
I have corrected my mistake. Please let me know if I have done it correctly this time, again thank you enormously for your help.
Israel
Message 6 of 8
(5,126 Views)
That works.  I'm sure Lynn appreciates the credit and is glad he was able to help you solve your problem.
Message 7 of 8
(5,121 Views)
Israel,
Glad to be able to help.
Ravens Fan,
Thanks for explaingin to our new member, Israel, how the Forums work.
Lynn
Message 8 of 8
(5,114 Views)
