FGV File Managemant Error 1 problem
The attached vi is a subVI from CLD exam boiler example. Why the following FGV subvi can be use in the other program without problem, but it cannot run on its own. When it runs own itself , it can do Open File action, but can't do Write Log Data and Close File action afterwards. It will have code 1 error when I tried to run Write Log Data and Close File after I run Open File. I understand that error code 1 happens when you lost the reference. However, Is that an explanation why it cannot run on itself but it is okay to run as subvi in the other vi?
(2,206 Views)
Accepted by topic author QianBath
When the execution terminates (the Running arrow turns back white), all references become invalid. This does not occur while the main vi is running.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,201 Views)
Hi Paolo,
Thank you very much for the anwer. That explains well, I thought it might be something like I click too many times of running. Thank you again, have a nice day.
(2,196 Views)
