FIFO DMA host question
@FraBaggio1 wrote:
So the problem is that I am generating more samples than the host buffer (that is in my case1Msamples=2^20). Is it right?
Correct.
Message 21 of 31
(1,790 Views)
Thank you Crossrulz,
I have another question. If I wanted the host buffer to be greater than 2^20 (that is the Excel limit) could I save data without passing from saving into excel?
Regards
Francesco
Message 22 of 31
(1,777 Views)
You are doing that now.  The Write To Delimited File does not involve Excel.  It writes a text file.
Message 23 of 31
(1,773 Views)
Ok, but if I set the host buffer at 1.6 Msamples it gives me an error. So I think that there is a limit in "Write To Delimited File" or not?
Message 24 of 31
(1,771 Views)
Probably an Out Of Memory error.
You might want to look into using a Producer/Consumer setup so that you can log in parallel and write smaller chunks to the file.
Message 25 of 31
(1,766 Views)
I saw the NI example, but I don't understand where to save data. In the consumer loop with a delimited spreadsheet?
Thank you
Message 26 of 31
(1,759 Views)
My recommendation is to look inside of the Write Delimited Spreadsheet and see how it works.  So for the consumer, open the file before the loop and close it after the loop.  Inside of the loop, use Array To Spreadsheet String for format your data and then Write To Text File to write it to the file.
Message 27 of 31
(1,758 Views)
And so, what would be the advantages of using a producer/consumer loop? This way I could store more data because data is written in small chunks?
Message 28 of 31
(1,748 Views)
The writing in smaller chunks is a bid advantage.  The other is that the logging can happen in parallel with the acquisition.
Message 29 of 31
(1,745 Views)
And how can I decide the chunk size?
Message 30 of 31
(1,741 Views)
