FIFO write / FIFO read data type difference
Hello!
My problem is my FIFO on the FPGA side is a fixed point data type:
Where on the host when I read the FIFO it is a completely different data type (U64):
This does present a problem since I have negative data. I've tried delating and replacing and the FIFO properties have it as a fixed point data type that is signed.
How do I fix this?
(2,244 Views)
Accepted by smahlen
How is your FPGA reference opened from the host side ?
If you are referencing a Bitfile, the data types won't update on the host side after you make a change to your FPGA VI.
You either need to recompile your lvbitx or change the reference mode to either VI or Build Specification.
(2,239 Views)
That helped me a lot thank you!
(2,166 Views)
