FIFO
I have been dealing with this issue for a while. I've got a Target Scoped FIFO and It transfers 1024 FXP elements to next loop. My SCTL diagram simulation crushes and returns false value for 'Input Valid' and 'Ready for Input' after nearly 4000 cycle. It works perfectly until it crushes so I assume there might be an overflow or underflow issue but I'm not sure how to handle this. I appreciate any kind of help.
Soffia
(3,535 Views)
Do you mean crashes?
If you attached code, it might make it possible for someone to help you.  It is impossible to debug words in a paragraph!
(3,461 Views)
