Reading text file on raspberry pi via deploying labview code
Hello all,
So, currently on my raspberry pi I run a program that obtains adc values that are going into the pi and prints them to a .txt file. I want to deploy my current labview program onto the pi and read from said .txt file to obtain the adc values. I have tried the read from file function in labview, putting the file path of the .txt file from the pi but labview does not like that.
Any suggestions?
Thanks.
(3,098 Views)
Hi rschulte,
when you deploy the program to your Raspi then you also need to deploy that text file…
(2,966 Views)
