FIRST Robotics autonomous has watchdog not feed when using autonomous iterative
Labview.gifCan anyone please help find a fix?
(3,864 Views)
Are you asking a question?  Are you having a problem?
Please put some additional information in your post.
Not very many people on the LabVIEW forum are familar with the FIRST competitions.  You may want to look at NI FIRST Community and post your question there.
(3,859 Views)
Sorry my text didn't all go under the picture. This is our current autonomous program. When we run this it says watchdog not fed and we cannot figure out why its not working.
(3,845 Views)
There's something wrong with Ravens link. All questions should be posted to the FIRST Community
(3,839 Views)
As others have said,you're more likely to get a helpful response by posting in the correct forum.
However, a quick guess - have you set your autonomous style to "Iterative" in Begin?
(3,812 Views)
Team 2317,
Hello! The problem you are seeing is explained in the following document:
[FRC 2010] Watchdog not Fed when in Autonomous Mode
Like others have mentioned, please use the FIRST Discussion Forum for all FIRST related support issues. Thanks!
Ben Sisney
FlexRIO V&V Engineer
(3,786 Views)
