FITTING IN XY GRAPH
Hello
I am new to LabVIEW and have problems fitting curves in xy graph.
I can fit in waveform graph, but not in XY graph.
Here is my program.
Thank you for your answers.
(3,779 Views)
Accepted by DODI
Hi Dodi,
you don't have problems with fittings but with graphical representation.
Both graphs show the same data - but in different "style"/"interpretation". The waveform graph shows both "plots" vs. the index of the plot items. The XY graph shows them "plot1" vs "plot2"...
(3,772 Views)
You are right. I made it .
Thank you for your clue.
I also posted one question about FIR filter. Do you happen to know
how to add taps as control in FIR filter?
(3,769 Views)
Hi Dodi,
your VI doesn't contain any FIR filter stuff!?
(3,760 Views)
I have usual FIR filter which has Lower cut off frequency control. But
it does not have taps control. Is it possible to make taps control to it or to select other block with same properties as this FILTER block?
(3,755 Views)
Hi Dodi,
have you read the help? Maybe this? Or looked at the FIR filter function palette?
Lesson learned should be: Never trust on ExpressVIs, when you need some special or uncommon functionalities...
(3,749 Views)
