FP-AO-210 No response from Labview
FP-AO-210 works fine with Fieldpoint Explorer. When programmed with Labview I cannot get an output? I assumed using a Fieldpoint Write statement is all that is required.
(2,671 Views)
You will need to use more VIs than the one you mentioned. I suggest that you look at the LabVIEW example programs that are installed with FieldPoint Explorer. You can find the FP-AO-210 example by opening a new VI and going to Help»Find Examples and in the search type FieldPoint. You should see the category "FieldPoint analog output". Select this and you will see the FP_AO_210.vi. If this doesn't work, you can search for this VI using the Windows search.
hope this helps,
Mike
(2,671 Views)
Thanks mrak1,
Labview was reading a non-existant file. .iak not .aik Thanks for the referenced examples - looked for hours trying to find one.
Thanks again
(2,671 Views)
