digital trigger causes error in the configured acquisition example
I had added a few vi-s to the niScope to allow me to trigger at every n-th pulse of an encoder signal.
The counter output of a 6024E is directed to RTSI1.
The 5102 scopecard is setup for Digital triggering.
After a few acquisitions i get an error message:
"Error occurred at: niScope Multi Read Cluster.vi
Error Description: (Hex 0xBFFA2003) Maximum time exceeded before the operation completed.
Elaboration: Possibly no trigger received. Buffers done: 0, Points done: 0.000000."
Scientia est potentia!
(2,680 Views)
Magyar
I have seen this problem before with the NI 5112 device. The problems was in the driver. You will need to upgrade to the newest driver. Make sure you have NI-Scope 2.1.4.
Here is the link:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BE600709528?opendocument&node=132060_US
Make sure you uninstall your current version before installing the new one.
Let me know if this does not fix the problem.
Brian
(2,680 Views)
